- Pick trends
- Create a private league
- And more!
Has over 10000 hours on it.
Old yzrider has a very good point about sticking with mechanical controls.
There are so many sensors and programing issues with new generation equipment, and any one of them will shut you down and drive you crazy trying to diagnose.
Have a friend that just got a new bobcat rubber track and it broke down 20 hours after warranty ran out. Took the dealer a week to figure out the problem.
There is nothing on my machine that we haven't been able to put up on blocks and fix ourselves.
Cab leans forward and everything is right there.
I have grouser tracks on rubber tires, and I have pushed rubber track machines out when they get buried.
I have a case 450c dozer also. They are kind of the same as far as mechanical. The older cases do not use steering clutches either. I do not have a ripper on mine, but one would be handy if you are working in dirt that tends to harden up.
Most machines that prep tracks aren't designed to handle the repetitive forces put on the frame and other parts. Basically they didn't design a dozer or skid steer to build jumps. If you plan to use a tiller for instance, most tillers can't handle the torsional forces of tilling around a corner multiple times a day. You'll blow a diff in about 2 months if you're lucky unless you buy a larger piece of equipment. These are pretty much go in a straight line machines.
If you lease and it breaks, they come out and fix it or replace it. Somewhat oversimplified but several tracks use this model to keep maintenance costs down. Food for thought.
There is a quick shot of my set-up at the 1:42 mark from the video below
https://www.youtube.com/watch?v=vI0eRm2SbvE
I found a good deal on a small dozer, works perfect for what we do here. It is different than the bobcat in many ways. I prefer it over the cat for certain jobs. Would not give up the cat for it though!
I have a medium sized 4x4 tractor for the grooming needs! You can't beat it for that task. My main grooming tool is a Perfecta field cultivator, but also have a pto roto tiller I hit it with occasionally. I can pack the track with a land roller or a 3pt attached land leveler!
My advice, get a good skid steer and a 4wd tractor. You'll thank me later lol!
The biggest advantage to a lease is that you usually have a good understanding of the residual value at the end of the lease if you trade in often.
99% of the time it's financially a better move to buy outright instead of leasing if you plan to keep the machine for many years. If you want to trade in every couple years on a new model, then leasing is a good choice.
(I guess I meant to say rent not lease. That should make more sense.
@aroark247 You should listen to this guy. hahaha
Just do some research before you buy, lease, or rent. What I do know is this equipment doesn't like track prep. Shit breaks much sooner than it should...but I'm probably wrong about that as well. haha
Thats realistically all you need. Tractor will pull anything you need to disc, till, set up drainage mow and whatever else you can thing of between jumps. And the skid steer is great for jumps, both maintaining and building new sections.
Also its really nice to have tracks over tires because the tracks dont dig ruts in the track nearly as bad if its wet.
While its great to have a dozer, yes i have used several of different sizes, theyre just not practical for most applications and are very expensive to use.
Fuel and wear on the bobcat is about $100 an hour and tractor is about $70 depending on what you're doing. Take that into account also when you purchase.
Also take into account with new equipment, if you can to afford to fix or replace a hydraulic hose or worse every month with that $1000 a month payment. Plus if something else tears up can you still afford that plus that payment.
Proper watering of the track is essential.
Post a reply to: Mx track maintenance question
