Eureka, CA
8/23/2015 7:05pm
Been riding for 30 years never seen anything like this. The bike was running fine. Made a hissing noise in a turn, I stopped and it went away. Thought it was mud or something in the chain. Rode a few more laps and it did it again but worse, then went away. Came back to the truck and it got worse but still intermentant. In the video the
bike is in nutural and when the noise starts the bike lurches forward! The clutch and valve clearance appear to be fine. Any ideas?
https://youtu.be/x5YTLN9_-7s
This video is private.
Sorry about that.
But it does sound like a bearing issue to me. Pull your clutch cover off and check the main shaft for play.
It could be a few things. Worn shift fork letting the gear try to dog in or the fork is bent.
The bearings on the end of each tranny shaft are sheilded,meaning they are back in the case with a tiny hole that lets oil get to the back side.,if it fails the shaft end has play and lets gears touch and will cause the lurch.
And,it could be a gear gaulding on the shaft and making it lurch. Some have rollers some just a bushing.
The big bearings usually dont fail unless the chain has been run tight and the countershaft bearing is killed.
Cases will have to be split.
It is tying up between the tranny shafts in some way.
They are either not parallel from a bad bearing,a bad gear bearing or the shift forks are letting gears touch.
[url=http://www.thumpertalk.com/topic/1080092-2014-kx450-whining-when-hot/ [/url]
A gaulded bushing would be my guess,shift fork if it fell on that side hard .
A problem with the clutch would not make it lurch while in the neutral notch.
Post a reply to: Motor noise need help.
