Tulsa, OK
On my 2013, 2015 and now 2017 KTM 450 SX-F's I run a high quality/dollar RK 520EXW chains. Great chain, however, the OEM chain sliders are wearing the top and bottom of the side plates down to where the loss of metaI makes me having to replace the chain well before it stretches or the link pins are worn.
Anybody else have this problem? Seems silly to replace a chain that is still good from a mechanical standpoint but not structurally sound due to the thinness of the side plates due to slider wear.
Chains are always adjusted properly on good sprockets.
I thought the OEM slider might be too harsh a material so I tried a Acerbis slider but same results. Hell, the chain is wearing out before the sprockets.
TIA
Rick
TIA
Rick
Possibly the TM designworks products could work better...anyone use them?
Chances are, you have been running the chain a bit tight as indicated by stretching your high dollar chain and flogging before sprockets, and I've done this to a bunch of different brand bikes to know exactly. Or you could ride in very course dirt, or you could be plain and simple, just lazy with the chain lube.
I also can't guarantee you anything, other than KTM's are not Kawasaki's.
Good luck with it anyway, shelling out unjustified $$$ on motos blows IMO.
That's why I tried the Acerbis but it looks to be wearing the chain about the same as the OEM. However, the Acerbis is actually showing wear and the OEM's hardly show wear at over 175 hours.
I don't ride in sand and chain is adjusted exactly as prescribed in the maual. Hell, I even use a tape measure to ensure it's right on and I've been riding 44 years.
Believe it or not, I'm an engineer and into data. I've logged hours and conditions on these RK EXW chains with and without being lubed. I honestly get significantly more hours out of the chain NOT lubing it and I've been running them for over 15 years. Same with my sprockets
Hey, hey, now!
I can tell this topic is over your knowledge level, so you best go back to discussing colorways, and other pointless grandpa shit
Post a reply to: KTM Chain Slider Wearing Out Chain - Any Solution?
