MOTO, IL
10/22/2016 1:59pm
Curious if anyone knows a list of common/shared parts between the Husqvarna 350/450 and the KTM 350/450 (2016/2017 models)? Aftermarket parts for a KTM will be a lot easier to find so I was curious what might work...full exhaust, foot pegs, shifter/brake pedal, levers, rotors, carbon bits (rear brake caliper guard/rear disc guard/etc.), etc.
Thanks in advance!
Thanks in advance!
everything bolt related
frames and subframes r different
Basically here are the biggies: Airbox/subframe, the seat, plastic, frame (mounting point for the subframe is different) some of the wiring based on where it goes into the subframe, triple clamps (I believe the bottom clamp has different mounting for the front fender) and a few of the bolts.
Thanks!
Do you have a 2017 you can send pictures of the hoses to us? Info@motohose.com
Thanks!
Post a reply to: Husqvarna FC / KTM SXF Shared/Common Parts?
