Help me design a track.
Just bought some property, and have room to build a small track. The space I've alloted is only about 60yds x 150yds. The property also came with a 1957 Ford 640 loader. Old girl, but pretty big, and should do the trick.
It's semi forested right now, so there will be some clearing involved first.
So anyway, how would you guys build a track in this space?
colintrax
Taylorsville, GA US
2363rd
10/16/2016 6:29pm
Leave the trees, and go up and down the hills as much as possible.
yak651
Appleton, WI US
192nd
10/16/2016 6:36pm
60 yards by 150 isn't very big, basically football field. Maybe look at some past SX designs to take some ideas from as that's the area you are working with
10/16/2016 8:39pm Edited Date/Time 10/16/2016 8:40pm
yak651 wrote:
60 yards by 150 isn't very big, basically football field. Maybe look at some past SX designs to take some ideas from as that's the area...
Come on man, don't short change me! 1.5 football fields lol.
It's a long and narrow section. Which makes it kind of odd to design for.
DuneRider250
Lemoore, CA US
10/16/2016 8:56pm
Can you send more pics of the area? Might give us some more ideas
10/16/2016 9:06pm Edited Date/Time 10/16/2016 9:11pm
It's literally just a relatively flat 60 x 150 yd rectangle.
I can get definitely more pictures, but I won't be back out there until next weekend. It's about 90 minute drive from where I'm currently living.
10/16/2016 9:44pm
This is the best I can do with Google satellite.
The building in the top right of the red zone is going to be removed.
St Helens, OR US
10/16/2016 10:00pm
Is this in Deer Island? Or did you head south some where? Btw , congrats on the new property!
10/16/2016 10:28pm
Headed east. The property is out in Sandy. My northErnest property boundary is the Sandy river. The track is for when the fish aren't biting hahaha.
Thanks man!
10/17/2016 5:01am
Honestly very hard to tell you how to build it. Boots on the ground and physically seeing the land is the best call. I've built 6 tracks, here are the basics. 1.) walk the track out, use spray paint to mark trees to drop. 2.) if possible ride a lap around purposed track layout, brushhog if needed. (A lot of things you or people imagine are much different scenarios on the bike) 3.) once layout is decided brush hog it as low as possible, then disc the track as deep as you can. (Again get some bikes on the track and see how corners transition, where things develope into one lane'rs) 4,) make sure track is on high ground or re grade areas so it sheds water. 5.) get it built before winter and let it sit, it will "cure" if you will and things won't deteriorate after a day of hard motos. Just my 2 cents.
Rowlands
10/17/2016 5:12am
I have a small track on a 4acre field so a little larger than you but this is the layout we have and it's pretty fun, you basically just got to use the most of the room you have and jump on the bike and see what suites. Keep us posted !
10/17/2016 5:20am
Considering the lot being very narrow i think you should go out and look for some shipping containers or something like that and those could give you some over under options so you can switch the track up a little bit more
DuneRider250
Lemoore, CA US
10/17/2016 7:40am Edited Date/Time 10/17/2016 7:40am
I drew this up, maybe squeeze some jumps or whoops and you could go at it all day. Maybe not push the boundary line on the bottom like I did but you get the idea
St Helens, OR US
10/17/2016 7:58am
I used to run and build all the tracks at an indoor arenacross called HindsightMX. The track path on many of those track layouts may work here. I'm not talking the jumps and so forth , but the path of the layout. You could do a 4 lane track pretty comfortably. Think of it as a mini Daytona track or something.
tprice07
Fort Dodge, IA US
10/17/2016 8:37am
Moens_Andy wrote:
Considering the lot being very narrow i think you should go out and look for some shipping containers or something like that and those could give...
That's a sick idea.
Personally, I would go through and let the area make the track for you. Rather than making arbitrary corners, go around the natural flow of the timber. I put something down in the darker spots, where it looks like there are fewer trees...or at least fewer big trees.
It really sucks taking down big trees and removing stumps. You'll spend tons of time and money doing that vs building a suitable track that looks more natural.
I don't know the different elevations of the dirt, but you can cut that in in the same manner, moving less dirt is always better. I always dig down in parts of the track that I want the water to flow to then I have dirt to build up the areas I don't want to be swampy or for jumps/berms.
One of the designs above would be a little boring for me, I like a mix of turns. Also, if you really want some fun build the track in a way that you can reverse it easily. Flipping the lips of the jump is pretty easy if you built up the landings.
jtiger12
Forest H Ill, MD US
10/17/2016 8:57am
asking a question here, how is the noise ordinance in your area? in HC maryland, a lot that size would not have enough setback to even make a track. We'd be shut down before the first section was cut and tested.
Flip109
TX US
10/17/2016 9:03am
This is at my friends house. It's bout that size I'd say. It's little but lots of fun.
Rowlands
10/17/2016 9:09am
Flip stick how did he get the dirt to make the jumps and berms? That place looks awesome fun
akillerwombat
Los Angeles, CA US
10/17/2016 9:12am
When I was a kid I used to call pool companies to see if they needed a place to dump the dirt they were digging up.
9 times out of 10 I would get a couple free loads of fairly rock free dirt out of it.
Cygnus
Hanover, CO US
10/17/2016 9:16am
That's a good size for a pond. Not a track.
Cygnus
Hanover, CO US
10/17/2016 9:22am
Flip109 wrote:
[img]https://p.vitalmx.com/photos/forums/2016/10/17/156008/s1200_IMG_2530.jpg[/img] This is at my friends house. It's bout that size I'd say. It's little but lots of fun.
The old arenacross double horse shoe is one of the easiest and best options on small spots.
10/17/2016 9:23am
Here's a second one I came up with. if you have any questions let me know!
SKlein
MN US
10/17/2016 9:35am
Now that's badass!
Post a reply to: Help me design a track.
