Seattle, WA
3/25/2016 3:57pm
Maintenance rook here... So I'm going to change the fork oil in my 14 RMZ250 but was wondering if I needed to take the forks completely apart to drain them 100% empty or if I could just take the caps off and drain for ~20 minutes and refill them.
Also... Just side note incase any one could help me here. Fork dives under hard hits or heavy braking in braking bumps. I can't get a revalve at the moment so should I add more oil? Thicker oil? Already bought springs that are right for weight and speed. Thanks!
Is there anybody that can help me with the oil draining procedure?
Thanks
Remove fork from the bike. -
Unscrew the top cap and slide the tube down a bit.
-Let them drain for 20min at least or just make sure all the oil is out.
-Refill
-tighten the cap
More oil will give you more bottom resistance. There is a fine line because too much oil might give you a sensation of a harshness at the start of stroke.(At least that's what I think I felt. Maybe start by going 15cc more then at the track add 10cc at a time.
Here is a YouTube video for the SFF fork from Rocky Mountain
Hope this helps
Post a reply to: Fork oil change help RMZ 250
