- Pick trends
- Create a private league
- And more!
1) Install a barbed-nipple fitting in the bottom of the tank.
2) Install a T-fitting inline with the fuel-cap vent hose, then put one of those little check valves above the T.
3) Connect a piece of transparent fuel hose to from the barbed fitting to the t-fitting.
4) Use wire-ties to route that transparent hose along the frame and keep it out of harms way.
The fuel level will be the same between the tank and the transparent hose.
You can use a sharpie or some various colored zip-ties to mark the hose at 1/4 gallon increments.
Carrying extra gallon or more is useless when running the typical 4 lapper with 2 gates and 27th in the moto order.
I ground some notches and got it down as to how much I needed for what was coming up,be it a short local or LLs moto.
Now if I could only figure out how much freaking gas I had left in my R6.
Post a reply to: Dumb question, but how to see how much gas in YZ250f gas tank?
