Dayton, OH
Baird
11/9/2011 11:07am
11/9/2011 11:07am
1/26/2012 1:30pm
I was hoping someone could shed some light on this.
There is a "Castle Nut" that is holding the bearings and spacer in on my rear wheel set (excel wheel). Is there a special tool required to take this loose? It also looks as if they had peened it on two sides.
Thank you!!
Thank you!!
It sounds like it would damage the nut but if you take your time cutting the right sized bit of metal it will be fine.
You can get one at pit posse. http://pitposse.com/47crsereto.html
one of the aftermarket companies, i thinks its fastway or allballs, has a rear wheel bearing kit that comes with the removal tool.
Post a reply to: Castle Nut holding Rear Wheel Bearings
