Santa Clarita, CA
1/27/2012 4:23pm
The copy is translated from Moto.it. I always wanted a Bimota.
Bimota BBX
Now, therefore, the Bimota are no longer just and strictly road. And this is in itself a significant piece of news. The unexpected BBX definitely the stand were two representatives of two different technical philosophies. The BBX 250 and 300 are fitted with a two-stroke single cylinder engine with electronic valve exhaust developed by Bimota same, like the chassis. This is a rather sophisticated engine, so much so that it is equipped with internal water pump (so you can, for example, remove the clutch without having to download the coolant), and starter motor in the front the base. The engine is mounted in a compact double-cradle frame equipped with components of great value, as is tradition of the brand Romagna. We have a Marzocchi upside-down from 48 or 50 mm in diameter combined with an Ohlins shock. Braking The braking system with discs Bat-fly, 250 and 200 mm and clamps machined from solid like their pumps with radial front, however, little choice in the usual off-road world. This bike should arrive in January 2012 at a price per hour hypnotized only around 9000 Euros.
Turning to four times here is the family of the BBX 400, 450 and 508 which should be available by next spring and who shares the same chassis of the two times. But in the near future is set to expand with the advent of a new motor currently under design, 250, 300 and 350 cc. All above models will be equipped with electric start.
Bimota BBX
Post a reply to: Bimota BBX bike 2 stroke and 4 stroke
