Athol, MA
8/10/2015 1:39pm
Hey guys im new here and any help would be greatly appreciated! I have a 1999 Rm125 and the clutch wasnt disengaging correctly so I replaced the Clutch plates and that didnt do anything. Then I replaced the clutch basket last week and it still is not disengaging. I may have installed the clutch basket incorrectly but im not sure. Is there anything you guys think I may have done wrong that could effect the clutch from not working when installing the clutch basket and clutch plates?
Thanks so much for the feed back!
-Steven
-Steven
Is the thrust bearing in good condition? Push rod worn or bent? Are you using OEM clutch springs? The part the thrust bearing sits on can wear out on the inside causing the clutch to bind up as well. And the obvious, clutch cable adjusted correctly?
I haven't used an after market clutch with OEM springs so couldn't tell you sorry. I know It's highly recommended to use OEM clutches in the RM125's though.
I have a Hinson basket and full OEM clutch. About 12 months old now. It's just started creeping forward once warmed up. I'm putting it down to a worn out clutch. Might be the aftermarket clutch in yours.
The RM125 OEM clutch springs are very HD.
Post a reply to: 1999 RM 125 Clutch help!
