MD
enu
Videos Bike Checks Product Forum
Need Help. Yz85 jetting issues!!!
MEMBER BLOG
hello all so I recently just picked up a 05 yz 85. Has stock jetting I just changed plug , air filter , and cleaned carb. Stock pilot stock main and needle clip is in middle position. I had it in 2nd position but bike was very boggish if you chopped throttle hard from idle. Bike idles fine. I played with air screw nothing really. Bike barely smoked I moved clip to middle and bike smoked alot but ran a little better low end wot is great no break ups or sputtering at all. Just right off idle. Very baaaaahhhhh then opens right up like a bat out of hell. Once I moved clip to fenter I played with air screw bog went away completely now but the air screw is adjusted all the way in. What is the issue here any help would be greatly appreciated. Im familiar with jetting someone but just need a little guidance if possible. Thanks all.
MEMBER BLOG
main might be a little big.
138 main
42 Pilot
needle in middle clip (NAPE Needle)
3.5 Slide
Fuel screw 1/4 turn out- Yes, that seems odd but it ran the best with this setup.......
Edit - HGS, DEP or Doma pipes work best on these bikes we found after running pretty much every pipe made......
Also, check your reeds for damage.
Even if it's running "good", put the clip back at number 2 just to know what that feels like. It might get worse, might get better.
BTW, what are temps like there? 2-strokes run leaner in cold weather. Also, are you using pump? That's fine, but that could be contributing to needing a little fatter jetting too.
I have this same problem. Bogs down low, and when you cracks throttle quickly. However It’s fine up higher and power band hits Hard! actually goes smoothly throughout if you twist throttle slowly and consistently. TIA!
Post a reply to: 05 yz 85 jetting help!!!
