Colorado Springs, CO
GasGas.com/us/ekids.html
MSRP $ 2099
Gas Gas E Kids - A true powerful miniature all-terrain Motorcycle
The Gas Gas EC Sr. has been designed to offer all the safety guarantees as children learn gradually, with a motor that can be programmed from a smartphone and LiMnCo batteries, which weigh less and have incredibly more “kick” and autonomy.
With an adjustable power of 600W up to 1.500W, it is way prepared to promote kids fun and take out the best performance possible.
The EC Sr. range has the best components-design-features ratio on the market. There is nothing else remotely comparable to it available.
EC Sr.
• Frame Tubular CrMo steel frame
• Front Suspension Hydraulic fork (wheel travel 100mm)
• Rear Suspension DNM gas shock absorber, preload adjustment (wheel travel 125 mm)
• Brakes Hydraulic brake system 160 mm front & rear disk
• Motor Controller 48V programmable top speed, power, throttle sensitivity and regeneration
• Power 600 W-1500 W / Max. Speed 52 km/h
• Battery 48V LiNiCoMn 8,8Ah with BMS integrated (Battery Management System) removable
• Rims Aluminum 12” x 1.60
• Tyres Mitas C19 2.50-12 TT 37m
• Weight 30kg
• Max. Pilot Weight 40kg
• Charger 54.6V 2A battery charger (4 hours)
• Others Power train management software included (RS232-USB cable required)
Includes power switch 50-100%
• Optional Bluetooth module via APP (iOS/Android) Remote parameter programming and parental control
• Torrot inverter for car charge (lighter socket)
• Designed and manufactured in Europe
Post a reply to: Gas Gas E Kids
