6/11/2017 9:44am
Hi guys, new to vital. All the way from Scotland. Picked up this KX 125 2000 for £400. Had been sat for years untouched due to engine problems. I started this a few months ago and just decided to start a thread. Most of the work is now done. I don't have a lot of time so slow progress. I'll be posting more pictures later on and a list of things that have been done. This was day one.
Good luck with the build. Nothing wrong with taking it slow.
Things that's been replaced:
Gearbox. Old selector drum was knackered.
New clutch hub and pressure plate.
New barrel, ported and a new sleeve
Prox piston.
Wheels, sm pro platinum.
Vhm head
304 shorty pipe.
Forks serviced, bushes and seals.
Front and rear brakes serviced
New sprocket and chain.
Replaced all cosmetic bolts.
New hand guards.
New plastics.
Tank repair.
Still to be done.
Pro circuit header.
Back wheel built.
Power valve cover. ( a metal one, not plastic)
Graphics.
Seat cover.
New discs
If any one knows and good little trick with these bikes or places to get parts would be appreciated.
Any idea on where the front number guard tab thing goes? There isn't any place to clip it on.
I ended up drilling a second hole to run the zip tie through and it allows me to pull the tab down tighter.
Sometimes you have to bleed the brakes quite a bit to get the firmness back in my experience. Even if you don't have any air bubbles coming out while bleeding, just keep doing it if you haven't gotten the firmness back.
I'm thinking of going all white with the plastics then some Redbull/Kawasaki/Pro Circuit graphics I saw from a race bike once.
Post a reply to: KX 125 2000 resto
