Cr85 shifting problem
soflo_will
Pompano Beach, FL US
Hello I'm having problems with my shifting lever for some reason it seems sticky when I up or down shift it the lever gets sticky I changed the lever yesterday and still has the problem I'm starting to think that it is my shift shaft any suggestions from someone who has experienced this problem thank you..
Hondas4Life3
Louisburg, KS US
10/8/2017 9:38am
soflo_will wrote:
Hello I'm having problems with my shifting lever for some reason it seems sticky when I up or down shift it the lever gets sticky I...
Sounds like the shift return spring on the shift shaft is broken. Or the shift drum stopper spring. You need to take off the right side cover to look at it.
Post a reply to: Cr85 shifting problem
