New Haven, VT
Hey, I'm new here to the forum and wanted to share a build that I have been working on for the last couple of years. I found the bike for sale on a front porch in New Hampshire for $500. My second 125 that I owned was a tricked out 96 RM 125. I wanted my bike back then to look just like Ezra Lusk's Factory Suzuki. So I decided that I would build this bike to look like the factory Suzuki's in 96.
This was the night I brought it home in the back of my truck. The engine was out in a box, I was hoping all the parts would be there. The extra set of wheels were powder coated black with yellow hubs. The chain in the box was flourecent yellow.
First thing I did was pressure wash things clean.
There were some issues that I found right away. The swing arm was junk. The previous owner must have gone ice riding at some point and the screws chewed thru one side. The chain adjuster bolt had broken and someone drilled thru it for some reason. I was able to find one on Ebay in nice condition to replace it.
The kill switch was a hacked and replaced with a lawn mower rocker switch.
The engine needed a lot of work. The crank was seized up and the kick starter gears were stripped out. I split the case and had the crank rebuilt. The outer bearings and seals were all replaced and then I reassembled the lower end.
For now I painted the frame gloss black. Its not the factory Suzuki color, dark metalic grey, but it will have to do for now. In the future I would like to disassemble and have the frame powder coated.
I cleaned the carb and added new vent lines. These blue lines are supposed to be ethenol resistant. The bike had some Works Connection radiator braces.
The bike came with an Applied Racing billet top clamp with oversize bar mounts. I found a gold pair of Pro Tapers on Ebay.
Due to the budget I decided that I needed to get the bike running and ride able. I reassembled it with the plastics it had when I bought it. They cleaned up nice with a little simple green and elbow grease. I decided I would use the powder coated rims and rebuild the other set with gold excels rims.
I found my old number plates that I had on my 96 RM 125 and used them on the bike.
If you look just in front of the clutch cover you will see a schrader valve. It is from an intertube and has been glued into the case. If you know what this is for please explain. On the inside it lines up with the end of the crank shaft.
Phase 2 - work out the bugs
The first ride was a success! It did however uncover some issues with the bike. The left radiator had a leak, it was a fairly slow one. The stock rads had been discontinued so I found some on Ebay. They fit okay, but had some issues I would discover in Phase 3.
The brakes were in terrible condition. The rear brake would push all the way down and not work. I flushed it with new fluid and it worked a little better. The brake pedal end was so sloppy I could never find it. I learned that a drz400 rotor would fit my 97 hub. Then I retro fit a 2007 RMZ 250f rear brake assembly onto the bike. I had to relocate the track for the rotor bracket. I also had to modify the tab for the master cylinder on the frame.
I found this pedal end on Ebay and machined the pedal to fit.
The suspension needed to be revalved and sprung for my weight. I wanted to upgrade the rear shock to a modern shock with hi/lo speed clickers. I found an 03 RM shock on Ebay for the swap. The problem I found was the length of the shock was different.
97 left and 03 right
My local suspension guy is Greg Lynk former mechanic for Buddy Antenez on Factory Suzuki. He really liked the project and still had some parts in storage from back in the day. I scored some plastics and work connection parts. He also revalved my suspension and swapped the springs. We were able to use the lower billet piece of the 97 RM shock on the 03 to correct the length.
So I ran the bike for the summer. I did a race here and there and then grenaded the engine. It was time to get some serious HP out this old RM.
The Athena piston off Ebay was not up to the challenge
I sent the cylinder and head to Eric Gorr. He does exceptional work! The cylinder was bored to a 295cc and he matched the ports. He also had to reshape the power valves to fit the larger cylinder. It was a big chunk of change to drop on a 20 year old bike, but it was worth it. The cylinder came back clean and ready to install. The kit included a beautiful Wiseco piston.
While I was into the engine it needed a clutch basket pretty bad. I found a nice Wiseco one on Ebay new in the box for a good deal.
I put a little Mother's on the aluminum rad and triples
I won a FMF silencer at the Stimlion MX challenge, finished 3rd in the "keepin it real" 2-stroke class. They have a class for retro bikes, the "Bring out your dead" class. Its a fun race that I try to attend every year and old RM brought home the bacon.
My buddy Gregg Lynk had a rear rim in his basement. I media blasted my hub and laced it up with new excel spokes. The old school gold rims are so sick!
I had a Works Connection hole shot device left over from one of my Honda's. It fit on the fork tube with a slightly longer clamp bolt. Its funny to see on the conventional fork setup.
I looked all over the place for the graphics without any luck. My buddy Chris at 139 Designs was able to put together a close copy of the original 96 Team Suzuki kit.
I put the graphics on the bike as soon as I got home that night! They came out looking great. Now I just needed to come up with a seat cover. I wish that I had punched holes in the tank graphics so they wouldn't bubble as bad. You get used to the modern bikes and forget about those details.
I finally got around to polishing my front hub and lacing the front wheel. I had to order a new rim and spokes from Lynk's Racing.
90's bikes rock, makes me wonder why in the hell I spent all this money on an EFI 250F when something like this could be had for significantly less.
Has anyone ever come across a set of 1997 Suzuki of Troy graphics like Mcgrath ran? I'm thinking it would be cool to have another set of plastics with these graphics. It would be cool to find the works forks and fork clamp too.
It was a great looking bike, won't be easy to get it the cover made and to match. Maybe start with the cover then find someone to replicate the graphics to line up perfect... You will be able to change the graphics easier!
http://www.vitalmx.com/forums/Old-School-Moto,22/Suzuki-of-Troy-Graphic…
The fork brace worked great!
Post a reply to: 1997 RM250 Retro Rebuild
